Popping sounds on track change in foobar?
Hey didn’t seem like there was a appropriate place to ask this question, but I’ve been experiencing a pop every time I change tracks manually in foobar… It does not happen when I let the track change naturally.
This has only been happening recently since I switched to the enog2pro dac, and I was guessing it might have something to do with it (maybe optical?) the strange thing is that it only happens with foobar. I checked with musicbee and I have no pops whatsoever.
I’m running foobar in wasapi (event) and I already tried it with push mode and direct sound and I still get the pops, so I don’t think it is wasapi related. output data format in foobar is set to 24bit.
anybody have a idea of what could be causing this? I was almost certain it was the Enog2pro but since i don’t get pops in musicbee I’m now thinking it’s a foobar issue or perhaps a combination of both…
Any help will be greatly appreciated
Could be that the moment you change track an incomplete package (data unit) is sent to the DAC.
In what driver mode have you had MusicBee?
I know in WASAPI (excl.) I get a moment of “incomplete frame” playing over my Focusrite 2i4 too. Does not happen in ASIO.
Musicbee is using wasapi shared… just checked with exclusive and it does seem to be popping as well in musicbee but no where near as loud as foobar… so i guess a issue with wasapi exclusive? it’s just strange though that I never noticed until i started using the enog2pro…
Edit: just installed wasapi shared for foobar and no popping! weird.
Is it more of a clicking sound?
somewhat… I don’t know. Sometimes it is very apparent and it sounds like a pop other times it’s more subtle and not as intrusive, more of a low click sound… kinda confusing actually.
I know some DACs will click whenever they switch between bitrates (like when you play a new track) – mine does in particular.
Which is perfectly normal, my bifrost 2 does that too. Might not be anything to worry about. If it only happens with wasapi, it’s defnitely just a bitrate change, where as in directsound, it just goes off of whatever bitrate you have set in your OS, so it doesn’t click.
