I hope this is in the right section, but please let me know if it is not.
I recently built a dream hifi for my wife and I, for our 10th wedding anniversary. Spent years speccing these components out, thinking about it all, and hoping I did not make any errors in the build.
-Marantz model 30 2 channel amp
-Marantz SACD 30n disk player + HEOS streamer
-pair of Klipsch rp8000f floorstanding
-audioquest evergreen cables
-Audio Technica + Drop VTA Carbon turntable
-audioquest powerquest 3 power protection / filter
The system is literally a dream come true for us, and has elevated everything we listen to. The music that comes out of this thing is gorgeous. But…
The house we rent is newish(2004) but the prior tenants may have damaged the internal electrical circuits. We notice black scoring marks on some outlets in some rooms, and some sockets don’t work. Landlord doesn’t know anything…
We also have a pair of Klipsch The Sixes (powered reference / monitor) that are not plugged into any power protection or filter other than a good strip. That speaker set picks up very slight DC hum from the fridge compressor. I can remove all sources and the hum is still there, showing it’s common interference.
The big problem: the Marantz model 30 has randomly gone into protection mode 3x in the last 30 days or so. To clear it you have to power everything down, disconnect wall power, wait 10 seconds, reconnect. An amber flashing light on the amp tells me it was protection mode.
I have removed all sources from the amp other than the paired SACD 30n, which is connected to the same audioquest power protection unit and the same wall outlet. Both units are connected to the “high current / amp” sockets on the audioquest. The only other source connected was a tv, which was wired into the RCA ins on the SACD/streamer/receiver unit. I removed that, and still the issue persists…
I want to pick up a really solid isolating transformer, UPS/power conditioner of some sort, but I am overwhelmed with the selection and wide range of quality found online. Does anybody have any experience with cleaning up dirty power using full isolation transformers or UPS? The audioquest powerquest 3 is supposed to reduce ground loop noise, common mode noise, RF, etc, but something is getting through. The Marantz gear is brand new and I’ve made sure wiring is good, cables are not run on top of any other unshielded cables or power supplies, and I’ve checked and re-checked everything. The circuit this is connected to is lightly used, with only a tv, lights, and bathroom ceiling fans connected to it.
Do you use filters/conditioners, isolators, UPS? If so, do you have any recommendations? I’m not even sure my budget right now, but am willing to spend a little to make this right.
