Does anyone have any experience with Pro Ject Audio’s Amp’s and Dac’s? They are one the options in Norway so would be good to know if they are a good option.
Well i have PRO-JECT MAIA PRE in use. It’s decent at least with the specs:
Power output : 2x * 25W/37W at 8 ohms/4 ohms (both channels driven)
Frequency response : 20Hz - 20kHz (-0,3dB, -2,5dB)
Channel separation : > 65dB at 20kHz
Noise floor : > -90dB (A weighted)
THD : < 0,07% at 15W
Gain : 31dB (measured via line level input)
Line level inputs : 2 pair RCA + 1 jack 3.5mm
Line input sensitivity : 350mV
Line input impedance : 50kohms
Phono input : 1 pair RCA
Phono input sensitivity : suitable for MM, MI or high output MC cartridges
Phono input impedance : 47kohms
Phono input gain : 40dB
S/PDIF coaxial input : up to 24bit and 192kHz
S/PDIF optical input : up to 24bit and 96kHz
USB input : USB Audio Class 2 requires USB 2.0 or higher on computer
USB data transfer : Asynchronous
Digital to Analogue converter : Cirrus Logic CS4344 24bit/192kHz Multi-bit Delta Sigma type
Variable line level output : jack 3.5mm
Bluetooth version: 2.1 +EDR
Bluetooth music receiver codec : aptX, A2DP profile
Bluetooth range : 10 meters in direct visibility between source and receiver
Speakers connectors: 4mm banana plugs, spades connectors or naked wire
Headphone output : 6,3mm jack (16 – 600ohms)
Outboard power supply : 20V/3A DC, suitable for your country’s mains supply
Power consumption : max. 3A DC, <0.5W in standby
Replacement battery remote control : 1 x CR2032 / 3V or 1 x CR2025 / 3V
Dimensions W x H x D (D with sockets) : 206 x 36 x 150 (165)mm
Weight : 1250 g without power supply
(Check manufacturer for tech.update specs)
Size is small also and clean.
Only bad thing it has is, when plugin in headphones. It will also play powered speakers… so automatic power-on/sleep does not keep monitors offline. So they need to turned off all the way.
Workaround with remote power plugs, so no prb.
