So just got my AKG 361, love’m!
everything is fine and dandy aside from the annoying cable…
I love hart audio cables but its so expensive to ship outside the US. So aside from a full-on custom cable, anyone knows of an adapter? or even a less shitty cable that works?
So far as I’m aware, it’s just a locking 2.5mm like what you find on the m50x/m40
Two issues with that
- Its not the same cable, very similar but slightly different as far as “bolt” itself (i had a m50 way back and i still have one of the cables)
- the m50 cable is just as bad as the AKG one
The top cable is the AKG, the bottom is AT, aside from being longer, you can see the notch isn’t the same
Eh, I own the M40, but not the 361. I can see 3 differences: the AKG doesn’t go as deep and the locking notch is a bit smaller and shallower(doesn’t go quite as far down)
