I am picking up a set of used Q701 and I am looking for recommendations on replacement pads. I will be using these headphones primarily for gaming.
Are you looking to go for stock pads or aftermarket? I hear good things about the dekoni q701 pads, I personally like the velour ones and the fenestrated sheepskin ones
I was actually looking at the dekoni but wasnt sure how they would change the sound over stock. I would like to stick with velour.
Their other pads change it more substantially, the velour is most likely the one that would change it the least over stock, and the fenestrated right after
