Rattling on speaker
My iloud speaker, left one developed rattling when playing music. I assume something came loose? Should I open it up? And what’s possibly rattling? Usually with the more bass the more it does itm
You done blowed it. Time for new speakers.
LOL. Also tat would have worked if I didn’t have other speakers! But I have the focal 80 alphas! Hahahaha.
Same thing?
Try pressing the grill a bit, will side noise end?
Thanks so I pressed around the top and speaker grills and the noise is totally gone. Not sure if that was it but it’s totally fine now! Thanks!
