Does anyone have good recomandation for In-ear’s that is suited for gaming around 200$-300$?
look for in ears that have a good soundstage and imaging, as well as good bass. Whether you are exclusively gaming, or listening to music, these two are a fantastic choice.
https://penonaudio.com/moondrop-kanas-pro.html
Felix
Isine 10s are currently 150, I’d say they would be a good option after EQ. If you do not own an amp dac the ES100 will make a good pairing. 250$ US total. If you need help with the EQ let me know as I’ve got mine baked in for it.
Thank you Mufflertape and Felix. I think I will go for the Fiio FH5’s since they are currently only option of what you two recommended in Norway.
Thank you very much!
good choice, I’m sure you won’t look back
Felix
Agreed, I think the sound signature will treat you well.
Happy to help with what I could. Hopefully you are able to get some more options in country or at least for delivery.
