My brother came to me and asked me to recommend a first hifi headphone setup at his desk for music while working…
He was coming from the airpods max, bluetooth headphones which he uses between office and working at home, and previously asked me for an upgrade on a bluetooth set that is better than the Airpods Max (which he hates - finds them uncomfortable - heavy clamp and he says the pads material are not comfortable, and he doesnt like the sound), for that I recommended to him a Bowers and Wilkins PX8, which he really likes so far. He says the PX8 sound much better and are way more comfortable than the Airpods, good noise cancelation in the office and transparency mode which while not quite as good as the Airpods is decent enough, better than say Sonys… So he’s happy with that rec after demoing them first at my place, he picked up a set discounted off Ebay…
Now he said he wants something that doesnt need to be that mobile but comfortable for long use and sounds a level above, and he asking for recommendations on a good desktop dac amp, and one open back headphone that would completely knock his current bluetooth headphones out, show him what a major upgrade would sound like that doesnt cost a fortune. He prioritizes comfort, likes something lightweight, he also said he wants it to have optional mic input so he could plug it into his playstation controller (which takes a 3.5mm w/ mic input) and have awesome sound
The frontrunners I am thinking to show him (setups I personally use regularly at my desk):
The Meze 109 pro with Schiit Magni Modi stack - in case he is willing to spend a bit more… show him what a solid open back DD playable off almost any device sounds like… Super light weight, super comfortable and plays well on almost any genre, honestly sounds good even on a iphone dongle, but thinking for his desk to just recommend a Magni Modi possibly with a Loki… It doesnt have the mic but he could add a separate mic via cable
Koss Porta Pro headset on a Schiit Hel - Honestly for pretty cheap, this setup I feel is pretty great - I am always impressed by the Koss Porta Pro for sound, easy to drive, sounds amazing and is really lightweight, and that boom mic honestly sounds really good! I have compared to airpods, to Jabra headsets, and his PX8, the mic just sounds way better than any other headset I have heard… Its cheap enough that he could probably even afford an extra pair to keep at work
Hifiman Sundara w Schiit Stack - He hasnt heard a planar before… This was my first headphone, its priced very reasonably and I am sure he will be mind blown as this has a superior resolution and sound quality and sound stage to anything he has heard before coming from bluetooth closed back headphones… Will also show him so higher end hifimans… Maybe show him the HE6SEv2 but he needs more amp for that imho to see its full potential…
Focal Clears… Not sure about this one, I love it but part of me thinks for the price I feel it wants a better amp to get the most of it, will show him, as well as the Radiance…
Senheiser HD800s… This also kindof might not make sense as its probably ouside his price point and but I just love that set… Also kindof want to see what he thinks - Its soundstage would knock his socks off and completely destroy any of his previous bluetooth headphones in sound quality… Might be pretty awesome for his gaming also
Some of these might also all be a bit pricey compared to what he had in mind, might be I should show him some more budget options, but part of me thinks he might as well go big and get the 109 pros and call it done ![]()
Any other ideas or suggestions?
