Replacement of headband Sennheiser HD560 Ovation I
New headband for Sennheiser HD560 Ovation I (around 1989~1991) seems to be difficult to buy. I was not able to find new one except some offer with absurdle price. That is why has been made DIY replacemnt headband:
Hello, I’m looking into doing the same for mine. How did you get the headband off? It seems like I have to pop the outer plastics off but they don’t do so easily. I just want to be sure if there is any trick to get it off and not break it hahaha. Thanks in advance!
Yes. There I is not any screw. Only plastic parts. In worst case, if will be broken, then replacement can be designed and printed 3D. You may consider to use any plastic tool for opening laptops or smartphones. Good luck!
