Replacement Velour pads for HD600
I’m looking to buy a HD600 used. So i wanted to get new pads for them. But pads from Sennheiser are like 50$ There are some 18$ velour pads ive seen for sale at Amazon. Do you think these are ok? will they give the stock HD600 sound? Or change it?
I would say go for genuine senn 600 pads, as typically the aftermarket pads change the sound a fair bit
I agree with Mon.
Sennheiser pads have a plastic mounting ring, the aftermarket pads generally mount differently and sound different.
