2020-10-20: First batch of iem measurements using the IEC711.
BGVP SGZ-DN1S
Co-Donguri Brass (4.4mm)
Final Audio E500
Final Audio F3100
KZ ED9 (Balanced filter, dont know where the other filter is lol)
KZ EDR1
KZ ZS4
KZ ZSE
Moondrop Spaceship
VE Bonus IE
Graphs are going to be uploaded into the “IEM Measurements” page and if there are multiple configs (due to filters/switches) they will be placed next (G2, G3 and so on) to the main config (The one I use).
Unfortunately as you can see on the graphs, the bass obviously doesnt look right but I have no idea why.
Graphs are tools, and tools are as good as the person that is using them.
2020-10-21: Second batch of iem measurements:
CCA C10
Final Audio E2000
Hisenior T2
KZ ZS7
KBEAR KS2
LZ Z04A
LZ Z05A
Periodic Audio BE
TFZ No.3
Tin Hifi T3
Along with updates to ranking:
Dunu DM-480 from B- to C
Hisenior T2 from C+ to B-
Thx for your efforts! But I’d try to fix the bass on your rig first before measuring your entire collection. Otherwise, it’s a bit odd to interpret it.
Usually, this happens when you have a noisy sound card (even an apple dongle + adapter would fix it), or just a bad seal. Also worth double check if your settings on REW are correct (https://www.audioreviews.org/rig-calibration/)
Thanks for the link. But I dont think it is the settings, because somehow I do get accurate bass readings IF I use a much higher volume:
(same iem, same everything just different volume.)
So this doesnt look like a soundcard issue either…and since im not touching the iem itself (insertion) it shouldnt be the seal…
2020-10-22: Third batch of iem measurements:
AZLA Azel
Audiosense T800 (Brown Knowles damper)
Final Audio E1000
Final Audio E4000
Final Audio FI-EVA2020
ISN D10
Intime GO
Kinera Freya
Peacock Audio P1
Sony MDR-XB75AP
Sony MH750
2020-10-23: Fourth batch of iem measurements:
Audiosense DT200
Blon BL-05
Final Audio E3000
Ibasso IT00
LZ A6 mini
Moondrop KXXS
Tanchjim Hana
ThieAudio Voyager 3
Tingker TK200
2020-10-25: Final batch of iem measurements!
BQEYZ Spring 2
Blon BL-03 (mesh mod)
Fiio FH3
Final Audio E5000
Intime Sora 2
LZ A6
LZ A7
Moondrop Blessing 2
Shozy Form 1.1
Shuoer Tape
Sony MDR-EX800ST
Sony XBA-A2
Tanchjim Oxygen
Tin Hifi P1
Urbanfun ISS014
Finally done and a total of 55 iems measured (not counting all the different configs some iems have).
I would appreciate if you would join my patreon, as this is really taking a lot of my money. :smirk:
TRN T3 (4.4mm version)
(top = Kbear limpid, middle = TRN T3, bottom = Tri Through)
Measurement: 0.19ohms
8-core cable with a working chin-slider. But the ear hooks are very strong and worst of all the connector isnt straight so when connected to a source it is a bit bent (fortunately it works). I got 2 cables and both have that same problem, guess TRN QC is pretty bad. Oh and the divider on the picture above (the one with the TRN logo) is actually as scratched/unclean as it looks…
Cant recommend it due to that and that we got cables like the Kbear Limpid and the Tri Through that are cheaper and of higher quality.
4.4mm version costs 28 usd.
Bought a used set of the Sony XBA-Z5 lol.
375 usd rip wallet
Dude I’m hype for you righr now, thats a good deal, also very intrested in the comparisons, nom nom audio info lol :heart_eyes:
Should be getting it next week. DHL FTW!
I definitely have high hopes for it and it is my most expensive iem purchase…yet :joy:
Depending on how much I love it, i might get the XBA-N3 as well. You know…because Sony stuff is more limited in units than regular chi-fi.
Noiceeeeee!!! Yo I suggest the jvc fdx1 from drop too eventually super worth
Got the Tanchjim Oxygen. That satisfies me with that type of signature. (and drop to sweden is extremely expensive!)
(also dont really like bullet style iems.)
Hahaha I really enjoyed oxygen too!
Its a great iem for sure.
The IT00 basically. Look like the finals with my personal EQ on
You can do a lot with EQ, some iems respond better and some worse though.
i just kinda wondered what headphones would fit that frequency range in EQ with the crinical graph… i can notice a difference where it feels crisper and more comfortable with the EQ
oh, I am not into headphones at all. So I cant help with that.
I mostly just meant iems but I used the general of headphones
