S3000Pro vs Kanto TUK
Just wondering what y’all think the move is, they’re for my living room and (possibly?) my bedroom, in a few months. I will also be buying a subwoofer in the future, for $500 or less hopefully. Thanks!
Hmmmm, well, personally I would prefer the s3000 pro as imo it’s the more capable speaker, but the looks of the tuk are very appealing. I think with the tuk you trade some sound for appearance, where I think the s3000 pro would offer better sound for the money
What type of music are you listening to?
Talk about dedication, what a timely reply. Appearance isn’t too important to me but I agree the tuks are pretty. I listen mostly to generic rap and r&b, but I’ve done verrry little research on speakers/subwoofers really. My budget is $500-800 for a speaker and $300-500 for a subwoofer, right now I’ve only really been looking at the s3000, tuk, and m300. I am quite a bass guy, I love a good rumble.
Ah gotcha, well you typically won’t get that rumble from just speakers, so you will want to invest in a sub lol. The s3000 pro is a solid and versatile pick imo. Some other options in the range might be getting an amp like the denon pma600ne and some Klipsch rp600m as those have pretty good low end for a speaker as well imo
What would you recommend as a subwoofer to pair with the s3000?
Hmmm, perhaps something like the rythmik lv12f or a svs pb1000, those would have the output you might be looking for while still maintaining quality as well
I should also say that I probably won’t be buying anything for eh 6 months maybe (at most). Are there any releases between now and then that I should anticipate? I’m not sure how the speaker market is when it comes to new releases and if I should wait until then to research.
Personally I haven’t been watching the speaker market too closely at the moment, and I can’t predict the future either unfortunately lol, so I can’t help you there
I would check a week or two before you go for something to see if there is something new out that appeals to you
Ah, thanks anyway
you can’t predict the future? but you are M0N, the all seeing eye! :o
