Saw many reports on 800st having bad isolation. I’m planning on using for travel on airplanes… would the isolation interfere with the overall music quality? I don’t mind turning up volume to the point where it drowns out the plane noise, but was wondering if the sound quality is impacted as a result of the ventilation ports & the bad isolation?
Have heard great things about S8F isolation, on the other hand.
Bass FH7>S8F
Mids S8F>FH7
Treble S8F>FH7
Soundstage and imaging S8F>FH7
Detail S8F has more bass and midrange definition, FH7 has a bit more treble detail (surprisingly)
So I think the S8F sounds more refined overall, but the FH7 is the more punchy iem. I really like the bass on the fh7 but I like the rest sound of the S8F more
Well by upgrading you are getting a better dac and amp, so that improves it overall. With a better amp you are able to better control the drivers in the iem yielding better sound and dynamics, and more detail retrieval and more refinement. The dac does the same thing to a bit lesser extent
Hmm, it depends on your priorities tbh. I think overall I would prefer the fearless but at times I would want the bass response of the fh7
I personally would have gone with a different iem that wasn’t mentioned for my tastes at least, but I didn’t recommend it because most end up preferring the s8f
It can be wireless or wired depending on what you choose, and it also has a built in eq mode so you could boost the bass to your liking if you felt it was lacking a bit. Another solid option if you want a warmer more relaxed sound is the ifi xdsd, but no eq but it does have a bass boost that’s pretty solid
The btr5 has better bang for the buck and a smaller form factor, while the q5s has a bit more features and better sound quality, but the btr5 does get close. Also with the btr5 you would want a balanced cable to take advantage of the balanced out on the fiio
It uses a two pin cable and comes with a single ended cable, you can get a nice 2 pin balanced cable like this for it. Of course there are other cables, this one is just an example (and one that I have tried and found to be solid for the price)
