Does anyone know if this unit works in reverse? ie. One input to two outputs with a switch to choose either.
From schiit’s site:
Volume control doesn’t work in this mode unfortunately though as it will distort this way for some if you don’t max the volume
I use mine in reverse. I dont have any distortion, but also no volume control. Pretty much max or nothing. Which is fine for my needs.
Read the website! why didn’t I think of that…
Thanks M0N
