just wondering if this is the correct connector for these cans, as I have already found a cable vendor;
- TYPE 4 DUAL SENN HD SENN HD 580,600,650, 660 and more
Should be correct one.
Yes. This is correct.
Thankyou for your feedback!
Alrighty, thankyou for your weigh in!
Hey there would love to hear what your experience is with this company i ordered a orange one from them and every time i move the y connecter piece close to your next my sounds cuts in and out
i ordered a cable from hart audio cables in a custom purple and green color and have had no problems with it
thats my 2 cents
I had another dood recommend hart audio cables, now that I know which connector end I need I may try them instead.
They tend to be a little βbetterβ then Periapt, only because Hart cables are not as thick, you can customize pretty much all you want, and cheaper. I prefer Hart personally.
Hart it is!
