Theyâre more tuned to be a neutral headphone with more of a focus on the mids. The bass isnât that great, and is the main reason the hd650 exists imo, but thatâs no bass monster either
Would the hd600 be a worthy upgrade from the hd58x? I bought the 58x when i had no amp or dac so it makes sense to upgrade headphones now. However, I donât know if this would be a noticeable step up.
It depends because itâs a different sound signature. The 58x has actually decent sub bass and extended treble, where the 600 is a little rolled off in those regards. The build and comfort are pretty much the same. The 600 also doesnât have as good imaging and soundstage as the 58x imo. The 600 excels at a neutral signature with great midrange timbre
Iâve been listening to these headphones off of a La Figaro 339 tube amp and they sound better than almost all my other high end headphones on the right tracks. I have some ZMFs coming, and I hope to get even more out of this amp with them, but holy hell do these headphones transform running off of a semi-decent tube amp. I also own the 6xx but to my ears these do even better on tubes than they do
IMO the HD-600 is the best of the 58* 6** Senn and MD cans. I think the 650 is a veiled, muddy attempt tp pump in some bass.
Iâve listened to these for 4 years on my Rag 1. Accurate mids for accoustic music - only the Voce may be better (800 S better can but not for mid purity). Then a friend lent me a BH Crack with the update, and whoa! Much better Buying a used 600 and BH Crack - and youâre under $800 with supreme sonics. On the BHC its amazing how the bass fills in from 60 Hz down to 30 Hz. On the Rag there is nothing there.
I donât like any of the pads except the original Sennâs.
As long as I own tube amps, I will own a pair of HD600s. I only own the 6xx to compare them to, but I agree that they sound much better. Plenty of bass off a tube amp. I also prefer the 6xx off of tubes, but not nearly as much
It looks a lot better to me, personally.
I kinda preferred the old marble look
It was definitely unique. So I can understand that.
found a used pair for 180
good deal?
Thatâs pretty good if they are in good condition and come with all the stuff
I think getting reasonably âfreshâ looking pads is important to take into account with the price too⊠if they look really worn, you might have to buy new pads which are usually around $50 or so.
Yes, getting new pads is something you want to factor in
unless iâm getting bamboozled, they actually look tip top. the plastic still looks new and shiny. very minimal wear that I can see
What color are the pads? And do they look stiff or squished?
black and stiff
lol
They look better than the ones on my 6XXâs
It seems like itâs in good condition lol
Hmm. I wonder why they did this. I had the impression they were discontinuing it?
Is the new color hd600 any different sound wise to the old?
