Hello, I’m completely new to a lot of high end audio. I want to use my PC as a source for my Magni 3, but I don’t have any way to actually connect it since I have no RCA ports on my PC. What should I do?
So you would need to get a 3.5mm stereo to rca cable which can be had for pretty cheap
Here is a good one that’s pretty high quality. You will want to connect this to the line out port of your motherboard if you are using a desktop. You can check the manual of your motherboard to see which out is the line out. If you have a laptop you would connect it to the headphone out but this isn’t as ideal
Alright. I’ve already got Line Out labeled, and I’ll go see if a store near me has any. Thanks a ton!
Perfect, any 3.5mm stereo cable to rca audio should work just fine ![]()
