Like the title implies I am lost - really like both formfactors as been for the longest wanting for the Topping G5(before the H5 was released) and already using the Fiio UTWs series.
Never gotten around to buy the Topping, and now I am planning to “Finalize” the home office which is now permanently working from home office. So want something that was BT for using around the house and on-the-go. Almost only using IEMs these days(contemplating if the time is to go CIEM) so don’t really need that much power but the H5 local play feature was why it peaked my interesse.
You probably can’t go wrong with either. I have never personally tried the Shanling H5, so I can’t really speak to those features. However, I did just receive my first pair of CIEMs and their phenomenal. I’d definitely recommend getting yourself a pair.
Its similar to having an impedence adapter but not exactly the same. its less about sensitivity and more about the impedance curve of certain IEMs. multi BA sets usually get impacted by higher output impedance far more than DDs. Its hard to tell how your IEM will react without trying it. I
one thing that was something I didnt think about between going true wireless (UTWS3) and BT dac/amp (Q5K) is that the ear hooks on the UTW3 are way less comfy than a cable. Im sure you will get used to it but I go back and forth often and Im always reminded how the sturdier hooks negatively impact fit
