So I current have a pair of dt 990 from beyerdynamic and I have those being powered by a sound blaster g5. Was curious if it would be beneficial to upgrade headphones or get a new sound card or upgrade both? Was looking into getting the Sennheiser HD 660s, Love to hear some feed back!! Worth noting that I primarily play games competitive ones at!
which version of the DT 990 do you have? there are several with different impedance.
The 250 ohm ones
well, the first step would be to get a proper amp and a DAC if you can afford one.
Got any recommendations?
Sorry about double post btw
what have you budgeted for your upgrade?
We’ll say 600
that’s a good budget to start with! aside from gaming, what kind of music do you like to listen to?
I listen to everything tbh rap and rock are probably the most listened to
