Currently running my HD660s on the Schiit Magni heresy and Modi 3+, I love the setup but have been thinking about upgrading to the Monolith 124459 DAC/amp combo. Will it be a good upgrade? noticeable difference? Thanks in advance!
these like power and warmth…so something like an iFi Zen DAC with balanced cabling.
I think there would likely be a noticeable difference, but not necessarily an improvement depending on what you’re looking for. What would you want to change about your current setup?
Appreciate it! ill look into these two. I was going to keep the DAC and build a Botllehead Crack w/ Speedball but the tasks seems really daunting and the price for the amp plus it being built is a little too far outta my budget.
Honestly really thinking about it I really enjoy my setup. I was looking maybe to see if there was better performance to be had out of the system.
If you want a little different flavor and a step up from the Heresy, you might consider the Asgard 3. Keep the Modi 3+ as your DAC, as to get a significant jump in performance, you’d be looking at something in the range of the Bifrost. Or, if you like what you’ve got, stick with it for now.
MT-602?
Hear the 6xx (not 6XX but 6-series… man that makes it hard) really love tubes and these are cheap powerful warm tubies. Combine with some Sylvania 6AK5 and you’ll have a creamy 6-series
