SHP9500 upgrade?
I’ve been using my 9500s for years now with the boom pro and I will keep them as my gaming headphones. Max budget probably like $250 , must be open back.
I’m mainly looking for a music headphone with some warmth and a bit more bass.
I usually listen to music on my home theater setup which I have setup with Kef uni-Qs all around. The speakers have great imaging so I would like to keep a good level of imaging for the headphones too
I listen to just about every genre of music. From technical death metal to J-pop to classical.
I was looking at the Fidelio X2HRs and the Sennheiser HD 58x but wondering if anyone has suggestions.
I had a pair of Hifi-man before but I really was not impressed at all, they may not be my cup of tea.
Tygr300-gRRRRRR
Follow-up, what are you running them off of?
warm, gaming, open back, 200 range, great imaging…
yep that would be the tygr 300r, but you may need an amp all considering
I would like it to run well off a Meizu MasterHifi adaptor as well as a FiiO E10K
The gaming performance I am not concerned with for this headphone really. I just want headphones that I can listen to music forever on and not get fatigued
Tygr still good even if it wont be used for gaming?
Yep, still works fine if you like the signature
