🔶 Shuoer EJ07M
Now available with a 10% off if you use the discount voucher at checkout :+1:
Also on sale at linsoul website, might be cheaper than amazon for you UK folks, but amazon has that sweet service
Ooo no not for me with Linsoul’s shoddy customer service and returns policy :grimacing: at least with Amazon you have some leverage if the worst comes to the worst :+1:
I read all comments about Ej07 og and Kinda lava. Is it KL a bassy version of 07 Og? Could I think it? About definition, resolution, voices, sstage…
Welp, EJ07M is on sale atm so I went in on a resin pair of Kinda Lavas. Hashing out the deets in the discord as I type this.
How much for a resin pair? :eyes:
$701 for resin with free shipping
This just in, Lava tuning is very good!
Just for fun :sunglasses: :volcano: :volcano:
Im customizing one resin model. Waiting results:)
I’m looking into getting my EJ07 in a custom resin. Has anyone here worked with Shuoer just using a 3d ear scan or can they only use physical impressions?
Tagging @shuoer otherwise they should have an answer pretty quick on their discord.
Oh custom resin doesn’t mean CIEM, it’s just changing the metal shell to resin, with appearance customizations of the resin IEM, that’s all. Makes the IEM lighter and potentially transparent if you wish.
Pretty sure they can do both, but reach out for Joseph and he will take care of you :slight_smile:
Sonically metal or resin are the same. Resin is simply lighter and customizable.
Also jumped on the short bus for a resin HBB KL while sale is on - hope the faceplate option I choose works out :crossed_fingers:
Not sure if anyone has also managed to get the cable ‘customised’ - so asked the qeustion in Discord to see if they will do me a black cable with black hardware.
If that an OG shell with lava tuning?
Su-weet
@Sonofholhorse just wondering what tips you use on your resin EJs? Just in case I need to get some more tips in to fit and stay on the nozzle :+1: .
I actually prefer the stock gray silicone tips that Shuoer provides for the EJ’s. The nozzles themselves are kinda ovular (as opposed to circular) so I find that softer tips fit/seal better. If you have any particular tips you’re wondering about, I can test them on my EJ07Ms when I get home (provided I have the types you want to test).
That would be great, thanks. I’ll give the stock tips a go - especially if the nozzle is shaped differently - but always seem to end up using spinfits cp100 M/L or cp145 the most, so would appreciate a wee test you have any to hand.
