I’ve been trying to hunt down a decent replacement cable for the my SRH840. I found this one but it seems a bit pricey.
Any alternatives I should consider?
What did you end up getting? There are a few ones on Amazon that seem pretty decent!
I found one on Amazon but it doesn’t seem available anymore from this seller. It’s better than the stock cable but the clothe wire is just okay. I also reached out to Periapt but they never got back to me about the connector.
https://www.amazon.com/dp/B0732VBW5H/ref=cm_sw_r_cp_api_i_VcwwDb8MSF2R4
What about this one?
https://www.amazon.com/gp/aw/d/B071V417DF/ref=ox_sc_act_image_1?smid=AJ2PJNO98VCDO&psc=1
I considered that one but I was looking for metal casing which I can fix if it breaks. If it breaks I will have to buy a new cable. However, I do like that braid material better than the one I’m using.
