I find a lot of headphones don’t really fit and those that do usually only fit at the zero clicks setting. I’m 5’10" I can’t imagine if I had the same proportions and was 5 inches shorter…
My head is small. Admitting is the first step to recovery.
I had the Vokyl Erupts and they would just fall off.
My new Zmf Verite fit with the zero adjustment setting but I have these goofy metal poles that always stick out like I have horns.
I have a pretty big head, hat-size wise, but I can also fit the ZMFs on the lowest setting oddly enough. Just out of curiosity, I’d ask you to try it 2 notches up to see if it feels any different. My instinct was that it would be looser, but instead it improved the weight distribution for me
