Hello! I’m looking to get a pair of headphones that isn’t super expensive (max 50 USD) but that can be portable and easy to use. I just need something that is simple, sounds alright (basically as long as it doesn’t have compression if Bluetooth) and has a detachable 3.5mm cable if wired. Zeos just reviewed the Marshall Major IIIs the other day but they’re just slightly too expensive. Anyone got any recommendations?
Unfortunately no detachable cable, but the CAL! headphones might meet what you want
I’ll look into it, got a link to it anywhere?
