Not long ago Elegia went on sale for super-cheap, and I bought a couple to gift. One of these is going to a friend who is into Mac stuff, hence I’m aiming for something inexpensive and silver-colored to match his Mac laptop. I’m trying to keep costs down around maybe $400 or under. Though that’s flexible if the perfect solution is a little extra. Whatever I get must play well with Tidal (somehow), and Bluetooth support (for convenience) is very important unless I just can’t make it work.
I’ve put together a D50s + Atom stack for another friend, so I started with something like that in mind. D50s, of course, may be had in silver, but small silver amps seem more problematic. In particular, the trouble I keep running into is output impedance. The Elegia is only 35 ohms.
The obvious choice might be an a50 with a d50s, but the SE out of the a50s is rated at 4.7 ohms. So, maybe, but the price is high and the damping factor is marginal.
Next I looked at the DX3 Pro, but the LDAC edition (which has literally everything else right), but that has an impedance of 10 ohms! Argh!
More recently I’ve looked at portable options, which might be the way to go. The XDUOO-05 Plus and Fiio Q5s look pretty promising. I think I’m leaning toward the FIIO since the XDUOO sounds seriously overpowered for Elegia.
Looking for any thoughts about the Q5s, particularly experience with Bluetooth or Elegias. Likewise, any alternate ideas for gear appreciated.
