So I’m on that 789 hype train and i was looking to get smaller length xlr cables for stacking the enog2 pro and the 789.
Problem is I only seem to be able to find 3 feet or more of cable wherever i end up looking.
I’m not a huge stickler for cable management, but I’d like not to have an excess of 2 feet of cable.
Any sources for smaller length XLR cables for a DAC/AMP stack?
Typing “short xlr cable” to google gives like few hundred options from what or where to choose.
Think the third link was Amazon, a 1"/30cm long XLR cable.
or just DIY as long you need for that perfect fit.
The 3 pin xlr standard is used to transmit a balanced mono signal. So you would use a 3 pin as a left and a 3 pin as a right. 4 pin cables can carry both channels for a single headphone cable
