I’m using an SMSL M500 DAC and sending the balanced output to my xDuoo TA-20 Amp. Both have volume controls.
I have been using the M500 to control the volume with the amp set at almost max volume. Now I’m second guessing myself… should I be using the DAC for volume?
general advice I have heard is keep DAC at max and adjust amp volume.
I couldn’t tell you exactly why but my guess is let the amp do the change in amplification? Maybe the input on the amp is expecting a certain voltage(?) range and you might not be within it all the time if you use the DAC to change volume? IDK
Also, at max, your amp might distort.
Makes sense, thank you. I was reading a review and it was mentioned that the volume was being adjusted by the amp, which led me to believe I was doing it “wrong.”
Thanks for the education.
No problem, Im sure someone else might be able to give you a definite answer why leaving the volume on the Dac to max and adjust the volume on the amp is the standard procedure.
As you may know, a lot of DAC’s don’t even have volume control!
