More information on the SMSL M200 DAC (from same ASR post).
Expected release date is mentioned to be sometime in January '20.
Translation by Google with some minor edits:
Main features:
● New series of design, with glass panel, high-grade and durable
● DAC uses AKM’s flagship audio decoding chip AK4497, ultra-high signal-to-noise ratio, ultra-low distortion support hard-dissolved DSD
● second-generation XMOS scheme, PCM sampling rate up to 32bit / 768KHZ, DSD support to DSD512. Exclusive custom driver for Native DSD
● The clock system uses independent ultra-low clock-off jitter, and the ultra-low phase noise crystal is used as the audio clock
● Built-in high-efficiency power module provides sufficient power for the decoder and uses multiple sets of low Noise LDO power supply
● Use a large number of audio special-purpose capacitors
● Specially-designed large-size Bluetooth LED display, clear and beautiful display
● balanced output
● multiple Digital filtering mode can be selected
● All-aluminum CNC precision machining machine to effectively reduce interference.
Parameters:
Input interface: USB, fiber, coaxial, Bluetooth
Output level: RCA 2.2Vrms, XLR 4.4Vrms
THD+N : 0.00015% (-116dB)
Dynamic Range: RCA 120dB, XLR 123dB
Signal to Noise Ratio (A-WTD): RCA 122dB, XLR 125dB
Bluetooth Specification: BT 5.0, APT-X, SBC
Power consumption: 3W
Standby power consumption: <0.1VW with true
Mon did you know that this company charges a 1000$ to buy this headphone with a leather case and a stand and a couple y adapters? On there website they’re selling a cable for 5000$
This is how you know a company is bullshit. I wouldnt accept their headphones for free. they should be boycotted
Their headphones are awesome, and while they do offer that stuff, I didn’t buy the extras with my phi tc. It’s not like you have to buy it anyway. Just like any high end company, there will be high priced add-ons
If you have a dac capable of it. Like the smsl su8. Ir even Enog 2 pro, just lower the output voltage from tbe dac and you would have no problems with IEMs.
im starting to wonder if i have a faulty one. i just dont feel the volume goes up that high. Mon do you think you can play a estat on them through a converter?
