So I just purchased the su-8. It was purchased from the US and I live in the EU, which is why I’m turning for help from you rather than return the product (not that simple).
Anyways, I plugged it in (after switching to 230V) and I get no sign of life. Nothing comes up on the display, nothing when I click/hold the power button. Same result after trying the remote. I know the remote is working, but I’m worried the DAC itself is faulty.
Anyone had a similar experience? And how did you go about solving it? Is it possible to fix it myself, or should I just bite the bullet and RMA it…
Thanks in advance for any help
