Solid dead flat studio mixing IEM?
Looking for a studio flat rec for critical editing and mixing; revealing flaws and precise. I’ve already got a primary mixing setup so looking for an IEM form factor specifically thats not too pricey (~$150)
Mostly considering the Etymotic line in general the ER2/3 and XR/SE variants, but also heard things about the Thieaudio Legacy 2 and Moondrop Lan 2 REF. Is the ER3SE’s BA timbre and details better than the 2?
Already tried the Truthear Hexa and OG 7Hz Zero and was not particularly impressed.
Thoughts?
I think you’d need a variety of IEMs to get a general mix that works with many different sound perception profiles.
And keep in mind, everyone ears/canals are different and it will absolutely change how mostly the mid/upper frequencies sound in the mix with both IEMs and headphones. Speakers as well as the pinna is in play.
Get more ears to listen to your mixes to get feedback if too dark, too bright, etc. Timbre isn’t an absolute either…we all hear/process sound waves differently.
See NF Audio NA+/NM+. Top notch timbre, very good resolution for the price, but a little bright.
What source are you using? It can just as important having a really silent noise floor with sensitive IEMs. The Topping Hane or Truthear Gate are really well tuned, and with Dunu S&S tips and a Fosi DS2 it makes a great combo for critical listening. I have those and there’s nothing you can’t hear for details.
One iem that will fullfill your demands is the Plunge Unity stage. Its flat, super resolving and detailed and works for all but music styles but possibly edm.
Mike
I’d only really use in ears when I don’t have my desktop dac, so ideally from my macbook’s output but I wouldn’t mind carrying something portable if I had to.
I forgot to comment on the Etymotics wich I own. For me the ER 2 is the best but remember the very special fit thats required for best sound. If properly fit ie deep - then sound is balanced enjoyable but not in the same league as the Plunge. Not even close.
Mike
Probably the Ziigaat Lush is a good choice for its price. I owned a set until I sold it for the Leteciel Magiris is just better than it. The Lush is a niche set, probably for people who really prefer that dead on neutral sound.
I haven’t personally heard it, but maybe hear this guy out?
That is a very good point about everyone having differently sized and shaped ears since this directly affects how accurate an IEM’s simulated pinna gain sounds to different people. Simulating pinna gain for the upper midrange always is a royal PITA for IEM manufacturers. Things are much easier when manufacturers tune headphones since headphones cover the entire ear.
hrtf still affects headphones (and speakers).
