I’m not sure if these are some proprietary connector, or if they go to a specific type of device. I just want to know if any of you can drop some specifications on me, or know how i might get these hooked into this:
The wires coming off one speaker or both, take some shots of the back of the speakers. If theyre passive you could take the clips off and connect them to the reciever. See if theres an ohm rating on the back of the speaker.
Seems like Sony has used that kinda of adapter at some point.
So removing the connectors and just hook the bare wires to new receiver.
But no idea witch one is + and - cables. Maybe battery check the polarity of speaker and as it mentioned the impedance load would be nice to know from speakers.
@Flaculence
“If they’re passive” Still not sure what you mean by this exactly, I’m not an audio nerd. but I really should’ve provided more info/specs on the speakers myself anyway, to be fair. I may also mention that the speakers I picked up here are collectively a 5-piece set (including the subwoofer) and if I remember right, I think they were plugged into a blu-ray player. Also, the “SUR” label refers to the “surround” or “rear” speakers, as there are “FRONT” labeled speakers that come with it- but they are EXACTLY the same in terms of model number, serial number, and impedance. As you can see, just one connector per speaker.
Here’s the pics:
So one’s 3 ohm, and the center is 6 ohm. According to this information, does this mean that can in fact NOT get this working under the conditions as @Andrew_Davis posted? (" If the speakers are 4 or 8 ohm…") Is there anything i can do? Should I try the method @MadGman posted anyway?
Thanks for the fast support, guys.
