You know these, you’ve maybe owned them or one of their close relatives (EX15LP - no mic or android controls, strictly for losers). According to Amazon they were released in 2014. It’s time to reconsider these endgame-on-a-budget classics.
Why these? Why now?
Well, struck by a sudden anxiety of an hour to kill with no headphones. I noted a nearby Currys store. For non UK/Ireland folks, I guess it’s a bit like Best-Buy or something. Think headphones, TVs, Microwaves, PCs etc. Looking at their range on my phone, and no wanting to drop some stupid money on some Bose TWS or something, I chose these Sony workhorses. I quickly found a frequency response online, and figured I can work with this.
Frequency Response - Sony MDR-EX15LP Measurement's report - Reference Audio Analyzer
Now the only decision I had left to make was which colour!
As blue was inexplicably €1 cheaper than the other colours, my fate was sealed.
The stock sound was, garbage. The kind of garbage you probably haven’t listened to in about 8 years. Imagine a child had been let free to fiddle about with your EQ. Like this, maybe worse. They weren’t overly bassy, but the treble was completely fucked.
I actually managed to get a quick fix, via the Sonarworks SoundID app (detailed elsewhere, I’m not going to get into it here, but try it, it’s cool). Withing 5 minutes, I had a listenable set.
The fit and comfort were both excellent, and they wear over the ear very well. They come with 3 size of silicone tips, but the fitted mediums were perfect on me. Isolation also not bad.
Next step, get them home and figure out a proper EQ (SoundID doesn’t reveal its secrets).
So I took the frequency response online as well as a Optimum HIFI target response (this a target I have some time for). I carefully overlaid them in Powerpoint (pro-move!), and I had a way forward.
My final EQ (for now) is below. What is the result? In my opinion these sound better than the stock tuning of IEMs I’ve spent more than 10 times the amount of money on (FHE I’m looking at you). It’s not even close. They are detailed, musical, natural. I suppose my point is why spend €150 on something badly tuned, when you can spend €9 on something badly tuned?
So if you have a pair of these laying about, or if you fancy dropping €9 on a new set - try the EQ, and let me know your thoughts.
If you really want something bassier, skip the bass low-shelf. But try with shelf first please.
EQ:
PREAMP
Preamp: -10.2 dB
BASS CORRECTION
Filter: ON LSC Fc 250 Hz Gain -4 dB Q 0.5
MID CORRECTION
Filter: ON PK Fc 2000 Hz Gain 3.8 dB Q 1
Filter: ON PK Fc 3000 Hz Gain 0.7 dB Q 6
Filter: ON PK Fc 4000 Hz Gain 0.3 dB Q 4
TREBLE CORRECTION
Filter: ON PK Fc 6000 Hz Gain 2.1 dB Q 5
Filter: ON PK Fc 7000 Hz Gain 1.8 dB Q 5
Filter: ON PK Fc 8500 Hz Gain 5.8 dB Q 2.5
Filter: ON PK Fc 8000 Hz Gain 2 dB Q 5
Filter: ON PK Fc 9000 Hz Gain 2 dB Q 5
Filter: ON PK Fc 10000 Hz Gain 2.5 dB Q 5
