@ZeosPantera What are those speaker isolation springs you are using in between the Miccas and Emotiva mono blocks and will you review them? If not do you recommend them for audio gear?
These are they. They come in a 4 pack. So I have two.
Thanks. Is this a review item or just a purchase? Do you notice any sonic difference due to the isolation or did you buy them because they look cool because I would buy them just for that?
There are some at Aliexpress:
But I have these - DEFLEX/MILTY FOCULPODS - VIBRATION ABSORBERS
At first because looks cool. However I finally figured out an ACTUAL place for them. Where my Crown amps sit on the Infinity subs in my living room. They isolate them from rattling!
