What is the best way to connect speaker wire to speakers that dont have binding posts but have the wiring clips that you just press down? Will banana plugs work for this type of terminal or can you only just put the bare cable in or is there another type of plug im unaware of?
Thanks!
I think bare wire is best for spring terminals. Giving the wire a bit of a twist helps to keep it from fraying. If it’s something you may be disconnecting and reconnecting regularly, lightly soldering the stripped ends will keep it from fraying permanently.
