Okay so here’s my current situation. I have a Monoprice THX AAA 788 Amp/DAC as my main headphone amp, I currently have it’s RCA outs plugged into my Edifier S2000pro’s, using it as a preamp to control the volume of the speakers.
I’m about to buy a secondhand DarkVoice 336SE tube amp to add some variety to my desk setup, I don’t want to buy another DAC just to run to the tube amp and I don’t want to be constantly unplugging and plugging cables. Can I get a RCA splitter and split the signal from my monolith DAC between the edifier’s and the DarkVoice? I’m never gonna run them at the same time, so I wouldn’t think it would have any adverse effect on SQ…
If this will work, what spliiter should I get? I would like something that’s not super cheap and won’t have any negative effects on SQ.
any advice or feedback is greatly appreciated!
EDIT: I was just reading some literature on the DarkVoice and apparently you can use it as a preamp for your speakers… would the Tubes affect the sound of the speakers at all by doing this? what are the upsides and downsides of using a tube amp as a preamp for powered speakers?
AudioQuest adapter - RCA male to two RCA female - hard assembly Amazon.com
Generally RCA splitters have no discernible impact on the signal. An RCA switch adds more components that might degrade the signal, like poor switches or cheap internal wiring.
RCA splitters help you to use a single output with two devices. There are some cheap options and they are very simple devices for example: https://www.monoprice.com/product?p_id=7186
I am having trouble understanding what gets connected to what.
So if I have active speakers, DAC/Amp combo, headphones that makes sense to me.
Speakers RCA → DAC/Amp combo → 3.5mm out to headphones.
Can you explain how these splitters work (like literally what gets plugged into what) in a setup like:
active speakers, standalone DAC, standalone amp, headphones.
