So if anyone uses any cables similar to the Seismic cables Z has endorsed. Regardless of brand, CHECK YOUR SPRINGS in the back. I have been trying figure out where this sound issue has been coming up randomly that sounds like static and I found the culprit. The springs were touching in the back due to a half twist from horizontal to vertical from my DAC to my amp. Because the amount of pressure is small I could hear the discharge between the 2. I have a temp fix with a piece of folded paper between the springs but if anyone hears static and thinks it’s from moving around in your seat, check your cables in the back.
