Hi there:
I have recently bought a Verum one that will soon arrive in my hands. The manufacturer tells me to use them with an e1da 9038s portable dac which is what I’ll do to get started. But I’d like to get a stationary + dac amp to get the best sound quality. I have been told that the best there is is Topping dx7 pro but I would like to know if there are other options at the same level so that I can search for them used.
Thanks for the help.
