I bought this power adapter, Works great with SRM-252S.
https://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_203036_-1
That sounds like Japanese voltage. Definitely get a 100v converter on Amazon, no reason no too and they are relatively cheap.
Testing L300 on new SRM-400S. They do scale up with better amps. Sometimes I prefer L300 to L700Mk2. L300 is more intimate sound where L700Mk2 has wider sound stage.
bumping this thread with my L300s in a sad state.
Anyone else have had their headband snap on their L300s? I know the arms are notorious for breaking on these things. Anyone ever have any luck fixing this with some kind of glue or is it not even worth trying to fix? One hundred bucks to get a replacement from Stax seems kinda steep for just a headband.
If you (or someone you know) has access to a 3D printer you can find the program online to print your own
Well itโs looking like I might have to go the route of 3D printing.
I tried super glue and after letting it cure it snapped on first attempt of putting them on. Canโt say that Iโm surprised but it was worth a try.
