Yeah I kinda agree. I wouldnāt really cheap out on the energizer. I would just save up some more for the l700 + a better amp
I heard these headphones are much better build than the mrk1, Lamda? But i also heard these have different tuning. Is that true?
Kinda, I mean it is a bit different tuning, but they arenāt worldās apart
what amp only costs $50 that you can plug the Mk2ās into?
Iāve got the lowly SRM-252S and I wouldnāt hesitate to plug them into it. might not do them full justice but itās Stax gear on Stax gear so will work and should do so safely ![]()
also, are the L500 MK2ās better enough to be worthy of buying or still jump them and go for the L700 Mk2? or L300 Ltd, if can be found?
I donāt know about the 50 buck energizer, but the 252s would work, but getting a higher end vintage stax amp might be beneficial. I think the l700 is much better compared to the l500 and l300. But the l300 limited would be a good choice
headamp.com still lists the L300ltd as available, but at that price Iād personally just continue saving up for the L700 MK2
that would be a good idea. i just heard a review where the guy didnt like the L300 ltd but loved the L700. so maybe there farther apart than we think. thats why im worried about the L700 mk2ās. i found one on sale but not sure if i want to flip the coin on it.
well, the L700 should sound better, and I would expect them to being theyāre still twice the price of the L300 Ltdā¦but they outclass the L300 and the L500. I just wish there was a Mk II with a detachable cable.
anyone have experience with older lambda models that they think outclass the L300 and L500?
I sure wish I could find my SR-207ās⦠![]()
thatās a good price. when I did a check a few months back, all I found were listings for used that were as much or more than the L700 new. LoL!
Yeah i like the metal holder for the L700mk2 headphone. hate all that plastic. But Zeos hasnt done a review of the L700 Lamda vs the L700 mk2
The mk2 has some metal parts if I recall correctly
Anyone ever try to power a L700 with a Woo WEE Dynamic to Electrostatic Converter and a SP200?
The woo wee only works with speaker amps
Oh thats right. it probably needs speaker wire input. do you think it will work well with a Onkyo A9110 amp? or maybe one of the cheaper smaller speaker amps on Amazon?
That would probably be pretty good imo. I also think something like the Denon PMA-600NE. You could also perhaps get something like a parasound 275v2 and a volume control or preamp
Is the Woo WEE really good? Iām curious about getting it as a cheaper alternative to the standard Koss energizer. I have some stout speaker amps to try with it so that is not an issue for me. ![]()
It is pretty good, if you have a good speaker amp you should have no issues. You will need a stax to koss adapter (or buy you rown)
The WEE needs a 5 million ohm resistor on the bias output, otherwise it will melt the coating off the diaphragm and arc. All Woo amps are like this.
According to a friend of mine upon adding the 5m ohm resistor itās the best thing to drive Stax with.
How can they sell it with a defect like that! Geez no bueno. I would prefer not to mod it if Iām dropping that much cash on one tbh.
Huh, I havenāt heard of this. Is this only for the WEE? I have a 3ES Elite and have no issues
