Presumably they are cheap because they are not as good as “real” energisers. If they are however decent enough, are they worth looking into? As apposed to going the ESP 95X route.
A more expensive version of something like this is the ifi iESL, and that does sound great, so it’s not necessarily the fact that it’s not a real energizer, it probably just isn’t as high quality as other offerings
Well, you could, but honestly the iesl and a nice amp might sound better imo. The iesl could be a bit cheaper though. It just gives you way more options
Even something like a 789 or 887 would be fine. You can easily go overkill though. I could use something like my headamp gs-x mk2 and it might get better
Lol or I could use my parasound Halo a21+ and never have to worry about power
I just finally got a good deal on an estat headphone I wanted to add to my collection, but I will just use the included amp
The SRD-7/Mk2 or SRD-7 Professional are the absolutle best ways to drive STAX without buying something like the Mjölnir Audio SRD-7 transformer box. You’ll need a good speaker amplifier to use with it, but they smoke every other integrated energizer out there period.
