So, I just wanted a simple recommendation on a sub for my JBL LSR305 Powered Monitors.
I do not have a big room (arround 16 square meters), so it do not have to be massive. I was looking for a value choice, preferably an active/powered sub because I don’t have an amp
The budget would be arround 200 dollars, maximum 250. But if I can pay less it would be good
Also, I am currently changing my setup from a 4mx4m room to a 4mx2m. But in a couple of years I will probably get back to a 4x4. So, if it works for both cases would be good, but the 4x4 is the priority.
That might be a good choice. But I wanted some varied options that would work, since I live in Brazil and it’s hard to find any audio related product here. So, having different options is very good.
