Hi,
I’m planning to buy these after putting a lot of time.
Which pads should i put for the HD668B.
Any recommendation would be helpful.
Thanks.
Hi,
Thanks.
Just saw no one had replied to your post. If you are still looking for pads, the BrainWavs hybrid pads are a great fit. definite thicker and much more comfortable. I also had some $10 cosmos velour pads that were nice…just not as nice as the brainwavs
