I’m in the process of starting my home theater build up and was wondering if anybody has experience with the Swan 3.1 kit. More specifically, does anybody know of a good center channel that would match up with this it. I’d rather buy just what I need rather than buying two kits and leaving the extra speaker in a closet.
I’d buy two kits and go with a 4.1 setup as a phantom center. I believe that with proper placement it would sound phenomenal.
What did you end up doing? I was thinking about this as well. Maybe you can take the second set and build a different enclosure that would house a WMTW center channel. A lot more work, but could be worth it if done properly.
I haven’t decided yet. For simplicity’s sake, I may just go with something I know I can match like the RP-600m. I don’t really want to risk taking a loss if I can’t get a center that I’m satisfied with.
i do not know how i missed this. you can source the parts once u guy the kit. ie buy the exact same drivers and crossover components, on their own.
alternately, you could buy a martin logan or similar center with an amt tweeter.
or two of u interested can split the cost of a second set and each take 1.
