This is the official thread for the Swans D1090
- Type: Bookshelf
- Powered: Yes
Uhm, since there’s not much info out there about those Swans D1090… Anyone here could help me out deciding whether I should replace my Edifier S3000Pro with those D1090? Since I bought the Edifiers from my European country, already imported, costing 550$ total (I have no idea why it is much less than the official 800$ here in my country…), those Swans will cost me a bit more than 400$ (because I already asked Swans and they said they have no plans to import to Europe soon) and it will be almost the same price as the Edifiers I bought.
I don’t really care about the so many features of Edifier or the small issues with the Swans, if they both sound at least equally detailed - the Swans will be my choice, only because of the more low end they have
P.S. What Bluetooth codec does the D1090 use?
What did you end up doing?
Well nothing so far. I will skip buying the Swans, the taxes and shipping will cost as much as the speakers lol… I will wait for some eventual big sale. Heck, even Focal speakers will be more worth it buying, since I can buy them from Europe.
Only place I found that sells swans in europe is https://www.soundimports.eu/en/home-audio/speakers/
I was looking for M300 and today I found out a local store in my country can possibly order some but I think the chances of that are slim.
So I will probably go with Edifier S3000pro.
May I ask why do you want to replace them and how have you been liking them?
Well, my only complaint with the S3000Pro is that their woofer seems to show a small defect that I recently noticed and some people also complained about. It’s a quiet sticky/rattling sound coming out of the sub’s port when the bass slams on high volumes (as if I hold a piece of paper near the hole). I don’t mind it when I listen to music, because I don’t like high volumes and I wanna preserve my ears, but it seems like only a dedicated sub could handle lows effortlessly and I’m considering this option, but it will be for the future I guess.
Also, apparently the Swans do more spatial magic than the Edifier’s, I would love to try them some day. Anyway, so far my Edifiers were amazing, that planar tweeter is very precise and clean, and I even use them for mixing & mastering on the flat dsp mode, so far it is pretty fine. Pretty much the best audio equipment I currently have.
Yeah, i’ve read about that bass problem as well.
I’ve found a place that will have them in stock hopefully next week for 465€, found it right before i was about to pull the trigger on amazon for 670€
Would also love to try the swans, but as they are nearly impossible to obtain here in europe.
These eddies for sure look interesting and have lots of good reviews about them, I am looking to use them for my living room tv/audio setup.
At the moment been using my old ass krk rokit 6’s that i bought way back when first getting into music production.
want something better
Um could someone share some insight on the issue / problem with this speakers?
Thanks.
They made in China with Chi-fi quality?
To go back to the original question about the Swans 1090s…
I just bought a pair. I’ll just say one thing. For the money, $399 I do not believe you can find anything better. It is true audiophile quality. The internal DSP is just magic. They are impossible to distort. They are limited only by the bitrate of the music pumped into them.
Also, no subwoofer required so long as you listen in an average sized room. Which is good because there is no subwoofer out port like say Galaxy 5s.
The fidelity is unmatched. The tweeters sing but are not so bright to overtake the midrange. The bass is lung vibrating so long as the digital signal sound pumped into them is sufficient.
If anything, my only complaint is that they sound great but not exceptional if you just push “normal” CD or You Tube 196kHz music into them. They reveal the lack in the source recording very strongly. And with the built in DSP, they refuse to distort, so that means they sound ordinary but well rounded if the source data is not high bitrate .wav files.
However ,if you have your music stored in your favorite lossless format these things for $399 deliver “the band is in my bedroom” quality that you might not get from speakers three times the price.
