Tanchjim revo (tws)
TANCHJIM REVO (TWS)
Musicality over technicalities.
✧ ════ •REVIEW• ════ ✧
「SOUND-SIGNATURE」
It is a well-balanced sound that is fun while retaining its natural timbre.
「BASS /LOW-END」
► Sub-bass leak is quite apparent. It doesn’t hit the deepest and not the atmospheric type either. The essence of rumble and boom is there but it is more heard than felt.
► Mid/upper bass is stronger in presence. It sounds denser and thicker in nature. It gives vocal and instruments a solid fundamental body and note-weight.
► Bass-drop can be heard but it is more on the background. Ghetto bass is bouncy enough, with traceable bass distortion elements.
► Kick-drum still packs a good punch. Meanwhile, drum-strike, slam hard enough for an impactful replay. Bass line guitar sounds more monotonous. The ups and downs of the hums and drone is less discernible.
Bass performance may not be its main priority, but it keeps the low-end sounding relatively engaging without sounding too flat.
「MID-RANGE /VOCAL」
► On default setting, the REVO becomes a mid-centric set. Vocal and instruments that becomes part of this region showcased good intimacy and immersion with its playstyle.
► Vocal and backgrounds elements don’t have the strongest sense of delineation. It is decently separated but the borders between sound bubbles don’t have the clearest of cut.
► Vocal texturing on the smooth size. It prioritizes tonality over transparency. In return, it gives listeners a smooth, natural tone that is truly pleasing to the ears.
► The mid-range possess a natural fundamental note-weight and body. Thinning and hollow effect is not an issue it be it a low or high range. Everything just sounds well-densified.
► Both male and female offer similar level of performance. Both goes for a slightly warmer presentation while retain a good dynamic-range that is wide enough to preserve its emotional delivery. The vocal sustains and decay rate is nigh perfect with adequate vocal extensions, allowing vocal to fully bloom before fading out.
► There is no vocal grain or harshness at far as my ears could tell. It handles shouted vocals well.
► Guitar plays do exhibit its warm tonality without trimming its bite point too much. Piano renders naturally with a clear distinct tap with clear overtones. Meanwhile, violin and cello do come across sounding more laid-back, focusing more on sustain and reverb to the notes.
Overall, it is such musical listen. It is one of those mid-range that is less technical but truly enjoyable to listen that makes you want to sing along.
「TREBLE / HIGHS」
► The treble leans on the dark side but it’s got sufficient reach to highlight the essential elements.
► There is no unwanted resonance coming from the highs. Sibilance control is well managed. It is relatively smooth even on its highest volume. However, it is not completely free from distortion, there is smidge of pixelated sound on certain tracks at louder volume.
► Transparency level isn’t the highest in the game even for its tier. The highs focus on giving the listeners a pleasant, natural tone to cover to upper spectrum.
► Hi-hats plays with natural pitched. Cymbals on the other hand will have a smoother note-edge with darker, less flowy overtones. The pops and cracks on drum snare definition are just alright. E-guitar offers just about enough grunt to make rock & metal sounds alive.
► On low-bitrates, the rate of compression can be heard. Same goes with less masterful tracks, the imperfections didn’t get glossed over completely.
In general, the treble quality is just decent at best. The definition is on the lower side, but it keeps things natural and easy to listen.
✧ ════ • TECHNICAL PERFORMANCE & OTHERS ════ ✧
The STAGE has enough width with a rather tall headroom. As for the depth, it is adequate to not like 2D.
Like most Tanchjim, their IMAGING is solid but with the Revo, it is not the sharpest. But you can expect an accurate placement with it.
INSTRUMENT SEPARATION is just alright. The borders of sound don’t have the clearest of cut. It will struggle a little when trying to give layers to a more complex track.
DETAIL RETRIEVAL may not be its forte, but it fits well within its price-bracket. It possesses sufficient fidelity to not sound low-res.
TONE & TIMBRE is one of its strengths; there is a pleasing sense of naturalness to the way it handles everything.
DYNAMIC-range is quite balance throughout the spectrum. It managed to render micro and macro dynamics well.
BUILD & PACKAGING? It is as basic as it gets. But is very well built. The earpiece and casing using high-quality plastic material with a smooth coating to give it a more premium feel. Aside from that, Tanchjim has provided users with a Type-C usb charging cable.
PRICE? For $35, I couldn’t ask for anything better. It offers decent sound quality and performs consistently well as TWS device.
✧ ════ •USER EXPERIENCE• ════ ✧
► DIGITAL APP can be DOWNLOAED via the official website or app store. It should be compatible with Android/ HarmonyOS/ iOS/ Windows/ MacOS. (only tested on Android and Windows).
► HOW IS THE POWER & BATTERY LIFE? [50-60% Bluetooth volume] [LDAC][Default Sound-Profile]
▲ I managed to run around 8 hours on a single charge. It is good enough for a daily commute.
▲ The white case can provide around 2.0 to 2.5 times of full charge which equates to another 16 to 20 hours realistically.
► ACTIVE NOISE CANCELING?
Not available.
► VOLUME MANAGEMENT?
With my Samsung S24 Ultra, I could get around 15 volume steps with its Bluetooth.
► CONNECTIVITY?
▲ Having “Tanchjim App” is crucial to run the REVO.The bluetooth connectivity will only active once you have brought out the earpiece out of the case.After that, you should be able connect to “TANCHJIM-REVO” and enjoy your music.
▲ It allows to connect to up two devices unless you’re using LDAC mode which limits to only one device.
▲ The strength of the Bluetooth connectivity is highly dependent on your Bluetooth device hardware. I could work-out up to 11~12 meters radius of distance. Above that, the connection becomes unstable. You could stretch it to 14~15 meters on unobstructed environment.
► 6 MAIN PRESETS:
✓ Default Sound (As-Tested)
✓ Theatre Mode.
✓ Instrument Mode.
✓ Pop Mode.
✓ Classical Mode.
✓ Ambient Mode.
► Supports EQUALIZATION :
▲ If none of the main presets works for you, there is customize EQ option, EQ forum as well as Game EQ to play around with.
► LDAC MODE
▲ You should always this on, it gives the best sound quality. Without it, your music can sound rather LOW-RES.
► CUSTOM BUTTON FEATURES
▲ Allows you to manually the control volume/playback/voice assistant with just a gentle tap on either LEFT or RIGHT side of the earphone.
PRICE?
▲ It is retailed at $35.99 USD. At this price, it is very good. From sound quality to user experience. It is a solid TWS.
→ CONCLUSION ←
I am quite surprised on how much I like the REVO especially when it comes to tonality. Sonically, it may not be the most technical but in terms of tonal balance, it hits the right spot for me (balance and natural). Hence, I could forgive its shortcomings and just enjoy it as it is. It is reliable, it is comfortable to wear, and enjoyable to listen. I couldn’t ask for anything better for the price.
TANCHJIM REVO
PRICE : PERFORMANCE [$34.99] : ★★★★ (9.0/10)
BUILD & PACKAGING [BASED ON PRICE]: ★★★★★ (9.0/10)
COMFORT : ★★★★ (9.0/10)
PERSONAL ENJOYMENT (BIASED) : ★★★ (8.0/10)
OVERALL : ★★★★ ( 8.75/10)
1-2 ★ - Appalling! please avoid this
3-4 ★★ Subpar offering, there are better options out there!
5-6 ★★★ Decent with some caveats! Not a bad pick! (CONSIDER)
7-8 ★★★★ Not perfect but solid choice! This should be in your shortlist. A nice addition to your collection. (SHORTLIST) (RECOMMENDED)
9-10 ★★★★★ One the best in class! You should go right ahead & buy one! A must have! (BLIND WORTHY)
PROS:
  • Warm, punchy bassline.
  • Natural and soulful vocal performance.
  • Smooth, well-extended highs.
  • Organic tone & timbre. Excellent sustain and reverb.
  • Expansive stage.
  • Average technicalities for the price.
  • Comfortable to wear.
  • Efficient and convenient to use.
  • Great value.
CONS:
  • Sub-bass leak.
  • Instrument separation isn’t its forte, will struggle on complex tracks like rock & metal.
  • Treble definition is not the clearest.
  • Heavily rely on input for the best experience (device/player/files).
SHOUTOUT TO TANCHJIM FOR MAKING THIS POSSIBLE!
Thanks for reading ╮(╯▽╰)╭
I tried ordering one a while ago (linsoul) and my order got cancelled lol
Ehhh guess its out of stock hahaha
