Starting a thread so I can document my system not sure where to put it so mods do what you need
Picked up another case just to organize tips, going through Spinfits range, really like the W1’s for fit. Also picked up a USB-C to spdif optical converter so I just have to switch inputs on the jtech instead of usb. Still USB on the iPad for now until I upgrade. All optical or coax digital now, removing barriers has been fun.
What kind of pads are on those grados? I’m thinking about changing my S pads.
This is the link I ordered from Amazon, doesn’t look like they are available but you may be able to find them elsewhere
Thank you much
