The Kiwi Ears Chorus IEM review
Overall rating: 3.5/5
Pros: Warm, punchy, and smooth tuning
Comfortable.
Cons: Lacks treble sparkle and detail
Basic accessories and cable
Price: ₹3,800-4,600
Driver: Single DD
Connection: 3.5 mm / Type-C
**1. What the market says:
The market describes this IEM as one that’s built for musicality with a good bass boost. It’s a single DD design IEM.
  1. Weight and comfort
    The IEMs are very comfortable and are lightweight; they weigh around 3.23 grams each.**
2. SUB-BASS​
Sub-bass isn’t that great, and it’s not that high-quality of an effect you get with great-quality sub-bass.
3. MID-BASS​
Mid-bass is the best part of this IEM. It’s really good in punchiness and quality. It’s a fun mid-bass that makes kick drums snap and is heavy. If you dislike a slight bit of a boomy effect, it’s not for you.
4. LOWER MIDS​
Lower mids add a good warm touch to male vocals and make them well-rounded, but this causes “bluntness.” Some instruments, such as guitars and pianos, are over-smoothed. It can be described as a weight/heavy or too low-mid heavy if you prefer thin/bright signatures. In general, it isn’t bad; it’s just different.
5. MIDRANGE​
The midrange in general is well-executed with no major complaints. Despite a good lift, instruments don’t sound muddy.
Female vocals lack energy and are over-smoothed. It’s not exciting. With a lower-mids rise, it doesn’t give the sound an “open” signature. It can be described as dull.
6. FEMALE VOCALS​
7. LOWER TREBLE​
Lower treble is actually not bad. Until 10K, it’s not too reduced, though I’d still describe it as a safe overall tuning. It’s a safe choice, as it’s not too bright.
8. UPPER TREBLE​
Upper treble is where this IEM completely suffers. There’s almost nothing past 10K, though I think it was done to keep it safe and warm. If you have a fatigue with too much upper treble, this IEM is a part of your dreams.
As a result, it’s too airy, and you will not hear a lot of details. It lacks a lot of extension too.
10. Conclusion​
For me, it’s like a miss or a hit. It will miss out on something in all genres, whether it’s pop, rock, classical, or folk. It doesn’t perform poorly in any of them.
I see this as a good alternative to the Zero Red, Klean SV, and Zero Blue 2 if you dislike treble, or if you are sensitive to it, or if you just want something warm, fun, relaxing, and easy-going.
It’s not my primary recommendation.
If you’re bored with other generic V-shaped tunings or Harman, this is an interesting alternative to explore something different.
A quick glance of the box contents​
  • Accessories do not exist. Could’ve given a good carrying case, at least.
  • It’s just IEM, cable, and tips. That’s it.
  • The cable itself is not bad; the earhooks are light and comfortable.
  • Tips are fine.
  • The size is small, comfortable, and great for smaller ears.
  • In general, it’s a comfortable, good cable (needs a lot of maintenance, though) IEM.
WHAT’S NOT GOOD AND WHAT’S GOOD IN THE FORMAT OF A GRAPH (IT’S FREQUENCY RESPONSE):
