My Tin T2 lost the filter on the right earbud and I had to take out the other. What could I use as a filter replacement? Any ideas?
Thanks in advance.
If you still like how they sound maybe try some of those comply tips with the mesh to keep stuff from gettinh in there.
I took the foam cylinders inside my Sennheiser OCX 685i and they work great. Exact size and the result is superb.
