I’m looking for more comfortable tips for my tint2 because those from T2 either are too small or a little bigger than that. I’ve tried misodiko S450 but the small size was not small enough to make my ear feel comfortable with them.
Before those IEM, S size tips from byerdynamic byron fit perfectly for me so could anyone recommend few brands with similar measurements that would be close to them (they are either 9 or 10 mm)?
Yes final e as well as spiral dots both can get small. Also the smalls on the horn tips are small but long so they fit differently. You can check the measurements on those too
If you can pick up the final e1000 cheap it has all sizes of tips. In USA it’s only 10$ difference max so you get free iems with the tips not bad backups too.
Supposedly a warm sound with better build for the 3000, the 1k is great as an emergency pair due to the neutral sound and small space/form factor. I don’t think I would buy them again unless I wanted more tips and wanted to give someone some decent audio for the cheap.
That is up to you, do you have neutral iems already? If you do then maybe you can skip it.
If you have stuff like the Tin Hifi T3, P1, Moondrop KXXS, Blessing 2 and they are all bright-neutral to you, then maybe you can get it. (those are the “neutral” iems I have and to me they are all bright-neutral, while the E1000 is true neutral.)
Regarding the main question of this topic I’ve just received tips from final Audio and after spending with them about 2 hours by now I have to agree that they are most comfortable tips I’ve ever known. But now I’m just still curious about spiral dots and if they have the same size? Compering SS from final audio with small from spiral
